Old 09-12-2001, 08:39 PM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
Grant, I've never heard of this problem. I suspect you're running your float bowls out of fuel. That would occur much sooner than fuel tank slosh would be noticeable. You didn't say which carburetor you're running, but I doubt very seriously if you could run your entire fuel line dry and cause your engine to starve.
I had the same problem with my float bowls on SPF#770 with a Holley 4160 750DP. The primary bowls were running dry under extremely hard acceleration. But, not until 3800 rpm in 3rd gear! The car would act like it hit a brick wall. You could back off the throttle, and it would catch back up with itself, but as soon as you got back into it, it starved again. If I accelerated easy I didn't have the problem, and even under hard acceleration, I didn't have the problem until I reached 3800 rpm in 3rd.
The fix? Easy...just adjusted the primary float height using the adjusting screws, Raised the primaries about 3 flats of the adjusting nut and it cured the problem. The fix was suggested by Dennis Olthoff, and turned out to be right on target. Raising the float height provided the additional fuel needed under hard acceleration.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
