Who built the motor Bob
xracerbob Bob before you do any thing, Who built the motor? Who's crank is in it. Call the machinist and tell him the problem and let him fix this. Yea you can add epoxy, liquid steel, or muffler cement to hold the bushin in there. You might also look for a roller bearing. SKF 6303-2RSJ works for FE cranks and GM input trans missions. Not sure which trans you have. You might call KCR, I beleive Keith has some oversize bearings. You can buy shim stock at some Lowes stores or home depots. I would start with the machinist. You paided for this motor to be built. This something he should have checked before final assembly. Rick L.
