Has anyone come up with a simple manometer to measure the relative air flow efficiency difference between stack,sock, and filter element. Attach item to end of vacumn cleaner extension tube, fit a small venturi jet attached to a vertical u-shaped hose with colored water into extension tube, switch vacumn cleaner on, and compare change in water levels. A good "Sunday morning after church" physics challenge.
