Old 03-05-2008, 04:51 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
A knurl will work fine. So will Loctite's #620 Bearing & Bushing & Lock. I've used this stuff in similar applications such as the outer race of a trailer wheel bearing that had to go into a wallowed out wheel hub. Green Loctite expands to fill a clearance of up to 0.015 in. between the OD and bore, then locks. Your application is perfect for this product.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
