Old 03-06-2008, 09:47 PM
Ronbo Ronbo is offline
Cobra Make, Engine: Kirkham #570 w Shelby FE
Well I did inquire about the aluminium with the engineers, their reply was "we specifically avoid aluminum contact with water".
Sounds like short of coating the water jackets with glyptol, there's no stopping the process entirely.
I wonder if you could substitue silicone oil or transformer oil for the coolant? We used silicone oil for dummy load cooling in the Navy. Ain't cheep at $40 a gallon but it's rated for around 400deg.
I'll see if I can find more info about it, this would eliminate the corrosion and barring external contamination would be perminant. The silicone oil is about as inert as you can get so there shouldn't be any gasket/seal issues.
I've been doing some digging and it appears that Amsoil has a coolant that is much more aluminum friendly than the glycol / organics. They claim near 0 material loss: http://www.amsoil.com/storefront/ant.aspx
I'm also wondering where the zinc from the electrodes ends up???
