Well it is some distance to Ron's shop from where we are. I don't think you need to worry much about checking up on the work on the car though. Ron's standards are much higher than most of his customers. I'll give you an example. Ron completed an outstanding paint job on my car. When the gasket material was installed between the hood and the body, the stripes in the back were off about a 1/16". I probably would not have noticed this until after I had the car for awhile but Ron did. He is in the process of getting the hood back from ERA to repaint it to fix the problem. I've also had Ron do some work on my Corvette (also a fiberglass car) he he did an outstanding job on the project as well. He communicates well and is easy to reach. He also has alot more experience with fibeglass cars than just about any local body shop will. this will make a big difference in how nice your car looks (smoothness, etc). when its done as well as how well the paint job holds up over time. Just some things to consider. Best of luck with your Cobra!
