  #30 (permalink)
Old 03-08-2008, 04:18 PM
Barry_R Barry_R is offline
I've only seen really high RPM out of hydraulic rollers in cars that were required to run them by the class rules. They "cheat" them into acting solid by nearly bottoming out the innards with the adjusters. They always seem to poop out on me around 6200 when run normally. But thats where they belong anyhow...
That dyno sheet looks like it had a safe and honest pull on it. I am pretty confident that you could wring more bragging numbers out of it with a leaner mixture - 12.0 coupled with BSFC around .5 shows it pretty safely rich. A bigger carb would also help with the glory part of the pull. I recently tried a 445 incher that made 455 on a 750 and 485 with an 850 - no other changes. Now - put that big carb and lean mixture on your motor and you'll have higher peaks but weaker throttle response, and a higher risk as far as fuel toreance.
Sounds like a nice engine to me....
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
