The pulley wont tell you if its internally or externally balanced or if its a 428. All FE's have neutral balanced balancers.
The difference between those two balancers pictured is pre-67 and 68+. Early versions had an integral pulley, but they are interchangable.
If you can see the flexplate (flywheel) that should tell you if its a 428, assuming its the correct one for the motor, or if you can pull the pan. It will have a distinct counterweight on the flywheel on one side.
Only other option is to measure stroke through the spark plug hole
1994 ERA Cobra, 496 Genesis FE TW (new addition to the stable)
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
