[quote=map;822832]Look at the damper the 428 is externally balanced.
You actually are just showing an early and late harmonic balancer. All the external weight is added at the flywheel not the harmonic balncer. They are interchangeable as far as balance. The SCJ had a "hatchet" weight behind the balancer to compenstae for the added weight of the capscrew rods, but all other 428s have a neutral balnce harmonic balncer with the weight on the other end.
I see I should have read through all the posts, my427stang already stated the same.
WDZ
