Old 03-09-2008, 02:00 PM
flipscobra flipscobra is offline
Cobra Make, Engine: Superformance aluminum427
Default Head Gaskets SPF
Hey guys just found a blown head gasket and the reason why it blew. The head bolts were not torqued right. Blew on number 3 cyclinder. I found out you dont have to pull the motor on a SPF, all you have to do is cut the motor supports loose an jack the motor up an over an put a block of wood under the motor support on the side your going to fix. Does anyone know what head gasket I need in FELPRO Gaskets. Southern Automotive built the engine. I had a bunch of loose bolts an missing bolts.
