Knock-ons
65cobra1,
Safety wire is NOT to advise you thatr you have a Knock-on coming off. Safety wire is designed to be used to prevent the problem. It should be twisted tight, with no loops and NEVER reused after removal. If you are anal, 2 per wheel are better than one. This material was used in aircraft (still is) and is designed to keep parts from coming off...not to advise you they are loose...what happens if the safewire tells you at 30,000 ft that your fuel whatever is loose and going to start spraying fuel on your exhaust manifold?
Jbo
