  #26 (permalink)
Old 03-10-2008, 11:04 PM
65cobra1's Avatar
65cobra1 65cobra1 is offline
Cobra Make, Engine: SPF #2450, Roush 342RE
[quote=mr0077;823497]Ivan, for an alternate opinion, many here believe that the wire is/was put on with a slack loop to indicate that the spinner has backed off, not to prevent the spinner from moving.QUOTE]
mr0077,
What you are saying is what the "Slack loop" group has been telling me.
Just to play it safe, rather than redoing the wires (At least not until I regen more blood cells), I'll put a small kink in the middle of the piece between the two attachments. It shouldn't weaken it and it'll be a good indicator.
Probably a good idea to tap the knockoffs every once in a while.
The wire spinner I used worked pretty well. It was threading the wire and making the end result look neat that caused the bodily damage.
In any case, I think I have the hang of it now for next time.
Thanks for the input,
Ivan
Forget the health food...I need all the preservatives I can get !!!
