Terry,
The release cables, although are bycycle shift cables they are made out of stainless steel cable. I have never had one break out of hundreds of installs and they work great. May I suggest you take the decal off the front of them, looks a little better, then pull them apart and remove the small white piece of plastic built inside- the 'clicker" this will make them work very smooth. Then take both flanges that actually wrap aroung the bycyle tub and flatten both out. cut off one end with the flair on it then install. They will be hidden by the front edge of the seat and will work great. Or you can go with full electric solenoids to open the locks by pushing an installed button- just more thoughts..
DV
