T5 Clutch Adjustment
I recently got my Cobra on the road & noticed the clutch slips in second & third gear when I get on it a little.
I'm using a T5 with a CNC hydraulic push type slave cylinder & Tilton master cylinder/pedals. The clutch disc/pressure plate are stock components, the throw-out bearing is non-hydraulic.
My question is should I adjust that slip out now or drive it easy for a few hundred miles then see how it is? Is there a "wear in" period on new clutch/pressure plates?
Thanks for the help.
Randy
Juggernaut
"Living the Cobra Experience"
