Thanks everyone, I really appreciate all the ideas. Ken I like your idea as it does not put stress on the block that a slide hammer would. Tonight I am going to try :
More heat (I think I will use a propane torch vs my oxy torch as I don't have a rosebud just a very small welding tip) to block only - damm aluminum soaks the heat up too well then use a ice cube to cool the pin and see if I can loosen it up.
I think the lower pin is accessable from the backsize if I remove my clutch slave cylinder bracket and if so I can drive it out from the front but maybe it is not drilled all the way thru...
If that does not work I need to decide to either do the weld thing or grind some flats on it...
Thanks!!
Russ
