Old 03-11-2008, 09:07 PM
Steve Bisson's Avatar
Steve Bisson Steve Bisson is offline
Cobra Make, Engine: FFR, Carb 302
Fred,
I'll admit there is nothing like cubic inches. Having said that, I've seen your throttle turns and parking. The ones that I have witnessed, your eyes are closed, your body is rigid and you’re screaming like a girl! When you finally get out of your car, your pants are wet.
David,
I agree. I find that as I add years I can use all the help I can get.
SuperHart,
My parts list is for the Factory Five MK II
1. The steering rack kit was purchased from Breeze Automotive LLC in Medway, MA. The kit included aluminum off set bushings, new tie rod ends and lower steering shaft assy. The power rack is 3 turn lock to lock made by Unisteer.
2. The pump is a rebuilt from Shucks Automotive.
3. (2)5/8" x -06 AN fittings and (1) 9/16" x -06 AN fitting from Unisteer.
4. Locally assembled pressure and return lines to fit above.
5. March serpentine 6 grove pulley.
6. Power steering bracket from Cobrastuf.com
