Rodknock ... I recently tried a Powermaster 9506 on my Quicktime bell housing/Ponds block and had a problem as the mounting holes in the three bolt starter flange wouldn`t line up with the mounting holes on the bell housing . Two would , the third wouldn`t . Went to NAPA and pulled an FE starter out of stock and it fit perfectly . I also called Quicktime and they had the same result with a stock FE starter . Looks like to me , one of the "ears" is off several degrees .... not the bell housing .I don`t know if this is one case only , or a series of incorrect flanges .... just an FYI for you . I think the number you want is 9406 , but Barry can verify that for you . My 9506 had what they called the infiniclock feature , which allows you to rotate the starter to fit , unfortunately , the flange had one ear off .
