Old 03-12-2008, 08:31 PM
DonC's Avatar
DonC DonC is offline
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Shawn:
I ordered the fuel system from Mass Flo with the setup for the FE in me ERA. Very pleased with not only the completeness of the system but the ease of installation as well. More than enough fittings and line for the entire installation. Even have several left over.
Chris appears to try to provide a well balanced system when you place your order with him. I'd call him first and let him know what you're planning so he can make whatever tayloring adjustments you'll need for your plans.
Tank pickup and returns:
Supplied in line fuel pump mounted to frame rail:
Passenger side of engine compartment after installation:
DonC
