The motor weight is way off
Joey_hv It sounds like a good deal. You have to remember it's a 390. That motor is all iron and the weight without the intake is over 400 lbs. An fe 428 motor with iron manifold is in the 640 range, take a 100 pounds off for the intake and you are still in the 500 pound range. It sound like a nice street motor. Alot of work done. Like someone else said I would still have the motor gone through before using it. Sonic check the bores. Where did he get the motor from would be the other question??? Rick L.
