I did pull a valve cover and saw some residual
oil; however, none dripping from the rocker stands.
Oil? (chuckle) Yes, 7 quarts in the pan and 1 in the filter. What is odd is that
oil was pushed through the oil cooler but not through the oil pressure line (which is the reason I'm going to check to see if the remote oil filter gaske was put on backwards).
Oh, Keith has already dynoed this engine so it has seen oil pressure (I hope).
Originally Posted by SSSammy
Pull a valve cover and see if any oil is getting to the valve train via the oil passage in the rocker stand. Oil should be dripping copiously from the rocker shafts after 10 sec or so with the drill motor.
And the obvious.. you did put oil in it, right? Keith ships them dry.
Sam
