Old 03-13-2008, 09:35 AM
undy's Avatar
undy undy is offline
If you encountered enough resistance where you had to shift from your battery powered drill to a 115vac 1/2" drive electric one then you're pumping oil. The oil pump DOES NOT need priming. Id hook up the drill again and hit it hard for several minutes with the valve cover(s) off, CCW as before.
Dave
Too many toys?? never!
