Old 03-13-2008, 04:34 PM
strictlypersonl strictlypersonl is offline
Underdrive and overdrive pulley sets might better describe the situation.
An underdrive set might drive the water pump and/or the alternator slower than it would normally compared to a standard set of pulleys. The number usually given would be a percent change from the stock speed of the driven pulley. The change can be made by changing the crank pulley or the pulleys on the driven accessories.
For instance, an engine has a stock 6" crank pulley, 5" waterpump pulley and a 3" alternator pulley. You can change the crank pulley to 5", making both the waterpump and alternator underdriven by 17%. Or keep the stock crank pulley and get a 4" alternator pulley for 33% underdrive on the alternator only.
Overdrive systems work in the other direction, but they are pretty rare except with superchargers.
