Thanks John. No hurry.
If you look at Art's pictures there is an interior view that shows the lever (page 2 picture 1000851). Is yours the same? I am guessing that there is a flat plate with a slot in it and a rubber gasket with just a slit in it that bolts onto the interior body panel. The lever would slide through the rubber gasket and into the slot. The rubber gasket then would not allow debris/water to come through into the interior. Does that seem about right?
Thanks, Terry
Reason: added location of the picture
