Did you also change the filter? It will hold 3/4 qt, and if you checked the new level without firing it up, the new filter was empty, so it would show over full...Not sure what the problem is if you didn't change the filter also...unless it is dip stick calibration or didn't drain completely as mentioned above.
Ken
