Old 03-18-2008, 08:32 AM
7968Jim 7968Jim is offline
Cobra Make, Engine: 1965 cobra replica (B&B), 460 ford
Default looking for performance parts for 460
after further inspection it looks like an ill designed pan was the cause of my oil starvation problems. flattened the cam & sent junk running throughout the motor. the crank is repairable, the cam bearings ok & the rods just fine.
i am looking for some suggestions as to who makes good pans for the application or to buy one some one has with windage tray, baffles, crank scraper.
also looking for used or new alum heads or ported & polished iron heads. want to increase compression, pistons are flat tops with valve cut outs & come within 1/16 " of deck at TDC. have crane roller rocker & guide plate with screw in studes. will be replacing springs.
a high volume water pump would be nice also
if you have any of these available for sale contact me.
james
Big Cubes = Big Noise = Big Fun!
