Old 03-19-2008, 08:05 PM
ou812545's Avatar
ou812545 ou812545 is offline
Cobra Make, Engine: SPF 2168, 418, TKO 600
-Flying Freddie, Thanks for the info and I wont ask you if your liner started to peel.
-JCoop, SPF did attempt to address the problem and with most tires I'm sure they did. I have sticky tires and they seem to kick up everything I drive over. I have not damaged anything yet, but I want to make sure I don't. The factory liner doesn't cover the entire wheel-well and is a bit thinner than the one I plan to install.
I will keep you posted.
Dan
