Originally Posted by hi-tech cobra
Thanks guys!
patrickt, what kind of water pump pulley is that?
Nothing you see there is fancy. The balancer and pulleys are all Jegs stuff, as I recall, and not on the expensive end either. The water pump is an Edelbrock. You don't need to spend a lot on this type of stuff -- it's the stuff that goes on the inside that tends to cost a bit more.
