|    Not Ranked
 Using the Contemporary mounting position, I am kind of limited as to where I can bring the pedals up through the floor.  That is why on one of my previous posts I attached the pic of the template and it had a curve back towards the driver, since the Contemporary is so far forward in the footbox, that is the only way I could think of fabricating it to get full pedal travel.  The last picture I posted almost looks 2 dimensional, when in fact the pedals are resting about 6-7" behind the front of the foot box.  In addition, I should be able to get some adjustment depending on how far I screw on the heim joints to the masters (?)  I could probably make these work, but how far from footbox should they set (I guess I will need to install the accelerator pedal assembly too and get some relative measurements).  I was just curious what the typical spacing was, and it does seem to be at least an 1" or so tight to the inside. |
