Mike,
Did you install the dowel pins that orient the pressure plate in the proper location on the flywheel? One of my friends installed a T5Z and a new clutch setup and ended up with a very similar vibration. He didn't know about the dowel pins and they weren't included with the new clutch. After disassembling, installing the pins and reassembling, no more vibration...
Good luck.
Mike
