Keith,
I have a small coolant leak at the front passenger side where the head meets the block. The engine has about 6k miles on it and is otherwise running fine. The
oil looks good - no coolant. I'm thinking maybe re-torquing the head bolts. What specs and pattern do you typically use to do this? Also, what do you think about the "AlumaSeal" powder that you add to the coolant to stop leaks?
Thanks,
Doug
