Thread: Roll Bar info
Old 03-22-2008, 01:32 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
If you plan on doing any track-work, you best do some research as to the requirements for roll bars for each group you plan to run with...I know a minimum diameter vs car weight rule usually exists, forward brace requirements (it can be removable), min. width between legs of a single hoop requirements, a hole is also usually required in the main bar for thickness verification, height above your helmet, the list goes on...easier to do now than retrofitting later...you know..."research twice, chrome once"...
