Old 03-22-2008, 10:01 PM
FST FOX's Avatar
FST FOX FST FOX is offline
Cobra Make, Engine: #42 BDR w/ a 408 KCM stroker
Default Last Bugs to work out before road worthy
1.) The clutch is not getting pressure, I have a wilwood hydrolic slave cylinder we went to bleed it and no luck , flush alot of old fluid out but still no dice.
2.) Oil pressure gauge goes to the far right once it's turned on, then once engine is started goes to the 1 on the vdo gauge, I'm going to hook up a freinds gauge to make sure mine is working right
3.) throttle sticks when pedal is depressed and no it's not getting stuck on the carpet, any ideas I'm going to lube the cable in the morning
The car sat for 3 months with out an engine and a new bigger engine was put in but no clearance issues with the above mentioned items
2006 King Ranch F150 Supercrew
Personal vehicles-2007 Escape
2004 BDR #42 with a 408 Keith Craft Stroker, Crimson with Silver stripes
