Old 03-24-2008, 06:59 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
I have moved the shifter from the front position to the rear position on a T56. It was Very Simple and would put the actual shifter change at a o.5 difficulty rating if it was a 0 to 5 scale. I removed 4 bolts from cover and 4 from shifter plate and moved plate and bolts. If the body or other things need changed then I can not comment as mine had plenty of room for either position, I did have to cut a new hole and put the piece in the old location but again very easy. The rail shifter has a block to accept shifter ball in each place. I used an old Hust lever and redrilled holes to match after cutting to a shorter length. Jeff C
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
