Old 03-25-2008, 08:16 PM
GlynMeek's Avatar
GlynMeek GlynMeek is offline
Cobra Make, Engine: Lonestar Classics, 302 stroked to 347; Metallic British Racing Green
I did a number of holes in my Lonestar after painting, and pretty much the way you described "do my measurements, use masking tape, drill a pilot hole to start and slowly make it bigger to fit the size of the hole I need." Not that difficult, but as always, MEASURE 18 TIMES, DRILL ONCE!!
I didn't counter sink under ANY of my drilled holes, and would be wary of that. The fiberglass is not THAT thick, and I would be really nervous about judging the depth of the countersink!!!!!
If the nipple is short though, I guess you have no other options. Can you find nipples with longer threads perhaps?
Glyn
Cave magister imperitus - Beware the inexperienced teacher
"No, I DON'T have an accent, this is how English sounds when it is pronounced correctly!"
