Thanks Baz, There are a number of RMC's running about which have a bush between the steering rack and the mount.
This bush purpose is to lower the steering rack and said to minimize bump steer.
I thought you may have also lowered the mount to do away with this bush. Mind you, that's with the shortened dunnydore rack and I'm told RMC is/about to use a different rack.
My steering rack mounts came from the factory at an angle. I've not measured it but I will on the weekend.
Les
