yep, as others said : AAA Card ( PLUS RV , upgrade charge- includes 100 mi of FLATBED towing , worth the extra cost - this AAA upgrade is called something else in different parts of the USA) , cell phone , Fix-A-FLat can(s) , 12 v portable air compressor and tire pressure gauge .
Be careful of your portable 12v compressor to ensure
(1) the wires /air hose will reach EVERY wheel from your electric source .I had one that reached 3 of 4 unknowingly and my flat was the one that it would not get to .
(2) if you use a 12v port make sure it does not blow your circuit breakers . Mine did , so I now have long wires with alligator clips that allow me to power source from the trunk located battery .
IF you carry tire plugs and fix/plug a hole , be sure to replace the tire asap .I would not trust a 'plugged' tire in these cars as they are typically driven in a more spirited fashion and I would want the safety of a unrepaired tire . Bill
