Old 03-29-2008, 03:35 PM
d_ford's Avatar
d_ford d_ford is offline
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
I ended up using the single 4 fuel log that was on the engine and using the new line from the pump to the filter, then I bent a line to fit from the filter to the log. I took a few pics so you can see where the "correct" 2X4 log hit on the oil fill tube, I assume from the tunnel port intake bolt configuration.
This next pic shows the final installation using my home bent line to the shorter fuel log. Not correct, but it works.
Hope this helps someone else who finds themselves in a similar predicament.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
