They would be open to ground.
Think about the points system your MSD replaces. One side of the coil to +12v the other is ground closure from the points.
It sounds like the voltage regulator is sending full excitation voltage to the field terminal on the Alt. So it's either a bad regulator or there is a bad ground connection to the regulator.
The voltage regulator will have up to five connections:
1: Power sense (to measure vehicle 12v).
2: Field coil in alternator (to vary output of alternator to load).
3: Trouble light out, normally supplies ground to alternator trouble light on dash. (this can be opposite supplying 12v on fail, depends on system)
4: Ignition (turn on/off output).
5: Ground.
Sounds like the ground is lifted at the regulator to me... Your alternator gets it's ground through the housing.
