Old 03-30-2008, 06:20 PM
lineslinger's Avatar
lineslinger lineslinger is offline
Cobra Make, Engine: 427 S.O. Dual Quad / Cobra undecided
Not sure I follow you Scufty, without good strong OP all those friction bearing surfaces break down in a hurry, I run 70psi at idle and 100psi at revs over 2k. Some will say this is excessive, but if the engine is sealed up properly this pressure setting is time tested.
