Old 03-30-2008, 08:46 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
That leaves the bearing in the crank, pilot bearing. Did you check or replace the pilot bearing diameter and input shaft diameter? If all is correct it just needs a wiggle. Not to scare ya but I have seen the needles of a roller bearing get knocked loose if banged around pretty hard.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
