Old 03-30-2008, 09:20 PM
hot427cobra's Avatar
hot427cobra hot427cobra is offline
Cobra Make, Engine: Kirkham KMP367, 427 Shelby
Lemans,
When you ordered the TKO600 did you get the shorten input shaft? You may want to check into this. I have an FE engine and recall having to change out the input shaft otherwise it would bottom out on the crank. There are some threads you can search which discuss this issue. I seem to remember some guy damaged his engine by forcing the tranny in with the input shaft binding against the crank. He started the engine and it screwed up a bearing or something like that. I hope this helps.
Mark
KMP 367 - Lite 'Em Up !
