Old 04-01-2008, 03:27 PM
iwantacobra427's Avatar
iwantacobra427 iwantacobra427 is offline
Cobra Make, Engine: SOLD: ERA FIA #2114 with 331
Default Trigo Wheel Offset
Anybody using Trigo wheels on an ERA FIA? I called Trigo and they said their FIA wheels have a front wheel offset of 3.650" and rear wheel offset of 3.750". I have Camaro front rotors and ERA standard rear end rotors (I'll have to use the Trigo adapter) with SSB Force 10 brakes and Goodyear Billboards. Any idea if this setup will work? What Trigo offset do you have? I did a search on here and found this to be the closest info, Bob posted this in 2004: "We machine about 0.4" from his (Lyn Park) standard setup, increasing the backspacing and narrowing the hub depth. Apparently we've already done a set like this but I was not privy to the process". Maybe it's easier and less complicated to go with PSE wheels?
-Thanks.
