Have someone check the current draw and voltage when cranking. Also, check the battery voltage (and at other points along the feed cable) when there's a medium load. Turn the lights and radiator fan on for the test. If the battery is good, you should see over about 12.2V where the cable attaches at the starter solenoid.
