Old 04-02-2008, 10:06 AM
bobcowan's Avatar
bobcowan bobcowan is offline
The reason you're blowing hoses is because the water pump continues to spin when the thermostat is closed. The bypass hose is there to prevent that. If you install a thermostat, you must have a bypass hose to relieve the pressure behind the thermostat.
You can install a remote thermostat housing like this one:
http://www.ipsco.org/Pantera%20Parts...ethhousing.htm
