Originally Posted by stephen low
Baz
I'd be interested in the answer too, as I had presumed from your picture that the top pivot arm looked the same as the jag part, or is the jag part used with the supplied parts.
What is the go with this part of the arm?
Steve
Steve and Low Belly,
No. The Upper Control Arm comes complete and the Jaguar Arm is totally removed. The Lower Control Arm remains Jag.
The Ball Joint that is supplied with the new adjustable arm requires a ferrule, so the taper of the ball joint matches the upright. Neil Streeting can supply these ferrules. Contact him at:
streeto@tpg.com.au.
Baz.
