Old 04-04-2008, 12:31 PM
patrickt patrickt is offline
Originally Posted by Nantucket427 View Post
I don't want to steal this thread but I would like to know how to wire a "Bump Switch"??
A cheap bump switch from the auto parts store will have two wires coming out of it with alligator clips on each end. When you squeeze the switch it will make a connection between the two wires so long as you keep squeezing. Put one lead on a 12v positive source, like the fat red cable coming off your battery, and the other lead on to your starter solenoid (usually mounted on your firewall). When you squeeze the switch it will engage your starter solenoid and crank the engine.
