Originally Posted by danc30
Undy,
You say the black pump is externally regulated. Does this mean I can shim it so it doesn't regulate at all so my regulator in the engine compartment does all the regulating/bypassing?
Thanks for all the help.
The pump requires no shimming and it'll pump about 14 psi unregulated. Just adjust your return style regulator to 6 psi after you install the pump and that's it.
Dave
