The differential has the mount cast into the housing. The Aerostar has a 3 link as a stock factory set up.....but the control arm is HUGE....which is why I had to make one. I think the single control arm from the 2007 Mustangs would fit just fine, but those were not out back when I put this together. I will get a pic of the axle mount for the panhard. I dont use a sway bar but I may add one to see what difference it makes, but the car does not lean much as it is now. Springs rates are 275 I think, but dont quote me on it..if so 300 would be better since these have the adjustment screw quite a ways down.
6th generation Texan....
