Never run any engine without a thermostat. The reason being the velocity of water through the engine is to fast thereby creating a larger than acceptable boundry layer next to the block. In simple terms there is not enough residence time for the water to take the heat away from the engine. Even a failed open thermostat acts as an orfice controlling fluid velocity through the engine.
