Old 04-06-2008, 06:36 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
Originally Posted by Rwillia4 View Post
peters- the problem on the early cars was a slip fit header to collector. My problem is on the other side engine to header.
jmimac- thanks from the web page it looks like they will do the job. Are they easy to port out to match the engine port?
Yes, they are actually somewhat fragile. They are many, paper thin layers of carbon held together with a resin. You can put them on the head with a few bolts and take a razor blade to notch them. Then take off and trim. Easy. Exhaust leaks really suck and these will absolutely fix the problem. You won't be disappointed.
